RCU Forums - View Single Post - ThunderTiger Rare Bear
Old 09-09-2015 | 09:52 AM
  #1882
willyuk
Originally Posted by Cougar429
Took up the Bear for a couple more flights yesterday and can say I have the controls pretty well dialed in now. In flight elevator limits to the specified 1/4" are all that are required, but on landing I need more authority. Upped the throw. Now just have to get the expo set so I don't balloon on approach.
However, it's getting annoyingly predictable for it to nose over at the slightest opportunity and guarantee to go over on its back on landing. Just does not like grass. My friend has his jet event coming up in a couple weeks and may ask to try it on asphalt once regular flying over with. Getting comfortable enough to fly it in front of crowds and this will hopefully prep me for some scale events next season.
Even though it does not like to slow down, it's not as fast in the air even with the cowl installed as I hoped, (think my Saito 100 powered Super Skybolt would blow past it straight and level). I tried a Graupner 3-blade with the original spinner and could not get it off the grass.
Only other tweak would be some elevator mix to compensate when the gear is up, (one or two clicks of down trim gets it back to normal).
One other negative is this plane needs a retractable tailwheel. Having that rather wide wheel hang out the bottom when cleaned up kind of detracts from the looks. Anyone know of one not as blatantly obvious, but does the job?
I fixed the nose over issue on grass by having a special landing/takeoff rate on the transmitter, I have huge amounts of up elevator available, with expo, far far more than recommended, in fact almost as much as I can get. Now it does not nose over as long as the grass is not inches deep. You just have to be careful on takeoff to release the back pressure as speeds builds and on landing as you begin the flare just gradually ease back on the stick, as she slows on the ground, I end up with full up elevator. This with the std mechanical retracts.
Trouble with the tail wheel mod would be added weight at the back and consequently more lead at the front!
good luck
Al
