RCU Forums - View Single Post - ThunderTiger Rare Bear
Old 09-09-2015 | 02:35 PM
  #1887
Stone17
Originally Posted by Air Sally
yes I believe that would work ...best to use some smaller high torque servos ...as tail weight means ballast up front ...but with a dle 20 in there you may need some tail weight. the vibes from that big motor is going to be hard on the airframe. do you know if you have the version 2 stabs? and the heavy duty C/F spar. read my posts on the spar I used a unidirectional C/F tube the stock one I had was a joke as it was not uni directional.
I can not tell.
Can I tell with out removing the elevator?
