RPM Question???
Hi,
When you guys are dialing your engines for a given desired RPM, are you setting it to GROUND RPM? I did that, then installed a telemetry RPM sensor and was pretty alarmed at the readings from the sky. I picked up 1500-2000 RPM in the air. Is this normal for a 60cc engine??
