As per instructions, "Locate the center of gravity (CG) which is located at the at the halfway point between the leading edge of the bottom wing and the trailing edge of the landing gear. A working CG range is 1/2" forward to 1/2" behind the exact CG. It is recommended to begin flying your Pitts at the leading edge position."
