How to get Throw even ?
How do you get the throw on rudder or elevator equal in both directions ?
I must be missing something! I start by turning the radio on with trims set at mid way neutral to get servos rest position, then adjust the surface to be neutral.
What do you do from there ? IE. Lets say the side that gets pushed always moves farther than the pulled side. And in this model the push rods cross per the plans if that makes any difference?
Jayd
