RCU Forums - View Single Post - SIG Rascal 110 ARF Build Thread
Old 09-16-2015 | 07:11 AM
  #35
SrTelemaster150's Avatar
SrTelemaster150
Default Pinstriping on the Tail Feathers & Wheel Pants
Worked for 2 1/2 hours in the garage this morning. Very tedious work, but worth it I think.
I re-worked the door outline. eliminating the square corner on the top front & taking out a slight dogleg near the bottom front corner of the window. I used a large "T" pin to simulate a door latch.
I think the striping on the wheel pants came out well..
I need to finish the port side of the fuselage & continue the bottom stripes around the cowl after I give it a few coats of paint to repair the CA over-runs.
Then, I can get the servos mounted in the wings & stripe them.
