RCU Forums - View Single Post - Super Skybolt ARF
Old 09-16-2015 | 10:50 PM
  #858
KaP2011's Avatar
KaP2011
My Feedback: (17)
Originally Posted by LSP972
I don't. Where do you get those three pounds from? The larger engines I am discussing are, at most, a half-pound heavier than an OS 91 Surpass (which I have, but in another model) and, I presume, a Saito 1.00.
But you're right, the 15"-16" props those engines require would simply not work with the stock LG. Which is what I suspected. Your information confirmed it; thanks.
Regarding the firewall… did you reinforce yours by adding a second thickness of real plywood, as detailed way back in this thread? I have no doubt that some additional fuel proofing will be needed, and perhaps some tri-stock here and there. But slapping on another firewall over the existing one is pretty… severe. Necessary, you think? Or not?
Off to check out the Saito 1.00...
The 10 lbs was just a number off the top of my head, my point was that you would be making a good air frame heavier. That 1/2 lb would have to be counter balanced some how.
As for my firewall, I replaced it after about my 3rd or 4th flight when I tested the stall speed at 3 ft off the ground. It popped out clean with very minor damage to the fuselage. I replaced it with 1/4 aircraft ply at that time. BTW, I believe the Saito 1.00 is lighter than the OS 91 and has slightly more hp. My 7.5 lb Ultra Sport with a Saito 1.00 w/13.5X9 prop has enough power to hover, though not enough tail to hold it for long.
