RCU Forums - View Single Post - Ultra Flash repair thread - step by step
Old 09-18-2015 | 04:41 AM
i3dm
My Feedback: (51)
Next step was to laminate the entire assmbly of foam / leading edge with thickedned epoxy (this is actually a small amount!) and laminate with thin CF sheet, to create the lower laminate layer.
this laminate was later sealed at the leading edge with another carbon fiber strip lapped over the LE.
This was left to dרy, sanded and then another coat of epoxy with the external CF laminate overlapping outside of the broken piece, into the wing to a joggle (original glass removed around the broken part, and airex was exposed creating a joggle).
after all of this glass cloth for finish.
ID:	2120442   Click image for larger version
ID:	2120443   Click image for larger version
ID:	2120444   Click image for larger version
ID:	2120445   Click image for larger version
ID:	2120446   Click image for larger version
ID:	2120447   Click image for larger version
ID:	2120448   Click image for larger version
ID:	2120450   Click image for larger version
ID:	2120451   Click image for larger version
ID:	2120452   Click image for larger version
ID:	2120453   Click image for larger version
ID:	2120454   Click image for larger version
ID:	2120455   Click image for larger version
ID:	2120456   Click image for larger version
ID:	2120458   Click image for larger version
ID:	2120459   Click image for larger version
ID:	2120460   Click image for larger version
ID:	2120461   Click image for larger version
ID:	2120462   Click image for larger version
