Originally Posted by
buckydr1
i did use. 14. 15. 16 .17. 18. and 19 tooth pinion . 14 tooth seemed to lo got real hot
That is very possible...while it is easy to Over gear a motor, you can also Under gear a motor. Under gearing it wont put a huge load on it, but it will be staying at max rpms a lot more of the time then if it were geared a bit higher...this can generate excess heat just like gearing too high which causes too much load.
Do you have a temp gun?
