Hi guys, need help and advise. I am using a single wire hinge point. You can see the hinge pin sticking out of the right elevator. I was thinking about using two separate servos for each half. Should a control horn of some kind be located as in my humble drawing or elsewhere? Or could a single control horn be made up to connect the two halves and only use one larger servo? There is about a 2" clearance between the two halves in the center. Forgot to say, I want to hide anything devised inside the fuse. Thanks for the help. Chic
