Hi guys,
I perhaps forgot to post a picture of the final internals (FUSE) showing the final setup such as servos, links etc........
Here is this picture showing such items and presently I am topping off the Separate Receiver Battery (Thunder Power 2-Cell, 1800mAH) from the switch harness.
Additionally, I didn't like the NUT look up front at the Propeller Adapter so, I changed the NUT for a nice F4U Corsair NUT.
Finally, changed out the Main Landing Gear tires as they were completely Flat and replaced them with a pair of Dubro Foam Tires (3-inch diameter) and made slight adjustments to the Main Landing Gear Wires and was able to give the model improved look and functionality.
