Jerry,
I don't have the Total Chaos plan but I did find an ad you guys ran in a Nov 1982 RCM magazine on it. see pic
Since the big deal with it was the longer fuse length and that it used a Curare wing maybe all you need to do is take a Killer Chaos fuse, which is already 60inches and use it as the basis for the Total Chaos fuse. see Total Chaos fuse plan below.
The Mk Curare Plan I have gives 56 3/4" for fuse length to the Killer Chaos fuse length of 60inchges. Both plans attached.
I'd like to see a Total Chaos with a longer fuse length like maybe 58 to 60 inches.
I took the liberty of modifying the Killer Chaos plan to look like the Nov 1982 ad as best i could and have attached it as Total Chaos Fuse plan. The fuse length it 58 inches, but could be easily stretched to 60 like the Killer Chaos.
The Killer Chaos has enough room for a 16 oz Sullivan slant tank so at least this could be a starting point until someone hooks you up with an original Total Chaos Plan.
Regards.
Bryan Hester
