Timing is set at 28-30 degrees before top dead center, checking as the magnet passes the magnet, If it fires as the magnet goes under the sensor that is one of the sensors causing a problem.
Makes no difference what name is on the ignition, If you look on the ignition box it will say RCexl on it somewhere.
I have about 150 of them that I changed out before I shipped ignitions.
I think RCexl knows about the problem but seems not to concerned about it.
As I posted above I just got a new order and they still have the problem sensors.
Milton
