RCU Forums - View Single Post - Fuel tanks help needed.
Old 10-18-2003 | 04:39 AM
Ian R
Default RE: Fuel tanks help needed.
Hi
Yes I would say the two tanks should be the same height as near as possible if in parallel, Also the tube connections should all be the same length and tube diameter. If this does not cure the uneven fuel levels check for blockages in the line, the clunks etc
Hope this helps
Ian
