Here is the video of the RC Extreme Power sensor,
The sensor works just fine, easy to install, one very small mod, I clear some material to allow the screw to slide closer to the center of the bracket to get me the 26-28 degrees that I was looking for, the other thing I did was to cut the mounting bracket short for my needs.
Notice the position of the magnet, right where it is suppose to be when we get a spark, the sensor has been positioned or slide to the sweet spot, that spot for this set up is a tad forward from the edge of the prop hub.
Thank you Milton for all your support and suggestions.
https://www.youtube.com/watch?v=H57j...ature=youtu.be
