RCU Forums - View Single Post - Inverted engine and uniflow system
Old 09-27-2015 | 12:44 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by richrfl
1Q, thank you for your input. I really like the solution althought the challenge is that IronBay seems to be focused in other market than our type of RC. It seems though that its owner may be ready to help using the phone connection. On the other hand, I found no way to access the Cline brand in USA. I will look into your suggestion of using a chainsaw or weedeater carb, but my concern there is if the hardware would work with glow fuel.
It is said the newer carburetor kits containing the diaphragms and such are supposed to be more tolerant of alcohol than they were in the past. I do know of a few fellows that have used the pump/regulator section of a Walbro carburetor to pump glow fuel to their engine with no ill effects. The key is to keep the diaphragm wet at all times. If you stop using it, the oil should be rinsed out.
The cline regulators sold today work the same way as the Walbro carburetor's regulator does but requires pressure in the tank for it to work without the pump.
