RCU Forums - View Single Post - Inverted engine and uniflow system
Old 09-27-2015 | 01:41 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by richrfl
1Q, considering the prices I have seen in some blogs, it seems that savaging a Walbro carb makes a lot of sense. However, I have looked to the weedeater carbs, and cannot figure our the size and connections to the pressure pump/regulator. The whole carb is 2 x 2 in, which is something I cannot afford. About the pressure in the tank, are we talking muffler pressure or something else? (never assume, you know).
Muffler pressure with a check valve if using just a regulator. If using a pump and regulator, then muffler pressure won't be used and the nipple plugged in the muffler. Here's a video of a guy using a cut up Walbro carb - he used the pump and regulator it looks like. http://youtu.be/1jjYAX3HhBw
