Originally Posted by
Silent-AV8R
I personally witnessed a test to destruction of a 8-channel RX a few years back. We applied a steady 6 volts to the RX and increased the current load in steps. We finally got the RX to fail at something north of 65 amps. Unless you do something really wrong there just is no way you are ever going to draw that much in a plane. I don't care how big it is or how many servos you are running.
EMCOTEC wired up a 14-servo 40% planes a few years back with on board data recording. They measured an average load of 4 to 5 amps total with transient spikes to 30 amps during snap rolls. This is consistent with my own experience with large gas planes. About 4 amps average with short lived transient spikes.
And finally, I've asked both Horizon and Hobbico if they have ever seen a receiver that failed due to current overload on the servo bus. The answer was no.
Bottom line is this is something you really do not have to worry about unless you have somehow managed to set your radio up so every servo can be simultaneously mechanically stalled.
Don't attribute that small trace vs amps to me. I copied that from TGWR's post.
Eloy Marez (sp?) did that test many years ago and published it in RCM. He got similar results.
Spektrum rates their receiver at 30 amps.
