RCU Forums - View Single Post - Inverted engine and uniflow system
Old 10-01-2015 | 08:12 AM
Sport_Pilot's Avatar
Sport_Pilot
So I still can't understand why you would say that a uniflow tank would have less change. If that is what you are saying?
Sorry I am doing a poor job of explaining this. Also I stated that the pressure of the fuel pickup is always changing , that is true but only because the exhaust pressure changes with engine speed and load.
Let's use all pressure as fuel head. That is because fuel density varies depending on nitro percentage and oil type and percentage, also because it is easier to visualize.
So for a full uniflow tank 3" tall and mounted with the bottom 1/2 inch below the spraybar, which of course is too high, so with a 10" exhaust pressure the pressure at the bottom of the tank is 10" and the pressure at the spraybar is 9.5" or the exhaust pressure minus the height of the spraybar from the bottom of the tank. We are of course ignoring suction pressure for this example, but assume it is the same in all cases. When inverted the pressure is still 10" at the top but now the bottom of the tank but the pressure at the spraybar is 7.5" or 2.5 inch's less. The difference in pressure iat the spraybar is 2" from upright to inverted.
Now consider for a standard tank. The top of the tank is now the bottom and bottom is the top. When upright the tank pressure is the same as the exhaust pressure or 10" and the pressure is 12.5" or the tank pressure plus the head above the spraybar. When inverted the tank pressure is now less than the exhaust pressure by 3" or 7" because the vent is now at the bottom of the tank. The pressure at the spray bar is another .5" (the distance of the top of the tank to the spraybar. or 7.5". That is a difference of 5" from upright to inverted. That is 3" more because with the uniflow tank the clunk for the vent falls to the side closest to the carb.
If you follow the same logic through you will find why I say that a standard tank should be mounted with the centerline below the carb and how much for the same height regular shaped tank.
