Originally Posted by
Sport_Pilot
With a pressurized tank needles will not leak air in, but will leak fuel out. So that is not the problem. I suggest that a bit of crud that was in the needle was pushed out causing the engine to run rich.
Sounds like a possibility. Surprising that the bit of crud could have been in there for a couple of years as the needle setting has been relatively stable for that long.
