Originally Posted by
acdii
3004 will be fine for the ailerons, not the flaps though, you need more torque for those. They will work OK for rudder, elevator and throttle, but it is always a good idea to use more than you need for the tail. If you want faster ailerons, the 3010's are good, but its a warbird, so 3004 are perfect on the scale side.
I have been using the Futaba 3003 and 3004 servos. I am going to re think that and use the 3004 as a minimum. Has anyone had a Futaba 3004 servo fail? I have been using them for three years now in this Mustang without any failure. Flaps and rudder too.
