RCU Forums - View Single Post - Rcexl sensor problems
Old 10-04-2015 | 09:12 PM
  #39
bcchi
Originally Posted by CARS II
Ok
I've been learning about timing, my DLE 35RA has a timing of 46 degrees from factory, I recently checked the timing out of curiosity and found it timed at 46 degrees, on the other hand I turned the shaft the opposite way and it sparked at 26 degrees.
There is no way I can make the timing 28 degrees since the sensor bracket can't be move, I was wandering if the factory timed the engine rotating the shaft the opposite way.
The engine runs good at that timing, the question here is will this engine run better if set at 28 degrees? and should it be re drilled to be able to move the bracket?
Any suggestion or recommendations?
Thank you.
LEAVE IT ALONE,It is OK.Can not be timed at 46 BTDC It would kick the snot out of you if hand starting.
BCCHI
