As you and others continue to muster the troops and have them fill out the survey, you may want to stop and check that 7 digit code that's attached to the end of link. For those not familiar, it's a unique identifying code. Check your own out, then pay close attention to the number. Look familiar? Islandflyer if that's the link that you got, and your repeating it here, you are sharing probably more than you think. Suffice it to say that only one completed survey result is going to be captured. The survey saved each answer as it was completed, so you could actually do it from different computers at different times if needed. So there's a chance that if you started your survey, stopped two questions in, then posted the link, and someone else went in, they could complete it. And might even answer the questions completely different than you would have. Sort of defeats the purpose no?
Rather than try to stuff the ballot box as it were and backdoor the survey, folks efforts are better spent contacting their district AMA AVP, or VP. If for some reason they don't feel like that is sufficient, write to the senior leadership. All of their e-mails are readily available, and this way you are talking directly to the policy makers, not having your information filtered through a third party vendor. Also doesn't hurt to saddle up next to one of them as they attend events, and just talk to them.
