RCU Forums - View Single Post - Rcexl sensor problems
Old 10-05-2015 | 07:54 PM
  #45
bcchi
Originally Posted by BadAzzMaxx
Timing is set at 28-30 degrees before top dead center, checking as the magnet passes the magnet, If it fires as the magnet goes under the sensor that is one of the sensors causing a problem.
Makes no difference what name is on the ignition, If you look on the ignition box it will say RCexl on it somewhere.
I have about 150 of them that I changed out before I shipped ignitions.
I think RCexl knows about the problem but seems not to concerned about it.
As I posted above I just got a new order and they still have the problem sensors.
Milton
Hi Milton and all,
I sure do not no what is going on with the RCEXL sensors.Xu Liang is aware of the compliant.He sent me six ignitions and a bunch of sensors. I could not make any of them double fire.I tried all of the new HV rcexl units my old system My new system . Adrians new unit.I tried a bunch of old sensors no double fire.I think xl is useing the Allegro bug same as I have been useing and I think Adrian also.Maybe he is useing a clone with alegro no.I no I am certenly no help.
Sorry. Could you send me one of the sensors that is double firing or a couple of them.Wish you could still get the old Panasonic buggs we used for years.Sensor must be Uni Poler not Bi Poler. My old circuit would double fire if batt voltage got to low,under 4.2 volts.
BCCHI Tired old CH guy.AMA 2500 origenal no. Too tired to spell check.
sorry
