(* The one condition I can see overloading the connector to the servo is if it stalls, that servo is going to draw more amps than the connector can pass. At this time, with the 3 pin connectors being used, this cannot be helped.)
The servo motor will burn out long before the connector.
That amp rating for the connector is for continuous duty.
The short term spikes will not bother it.
