Originally Posted by
myersflyers
helps with throttle response to reduce residual thrust on big blocks in smaller jets
But, you can do exactly the same with the normal mixers and a point curve ?
(apart from that, I can't understand how you can lower the residual thrust with a curve ? The lowest RPM is the lowest RPM no matter how the curve looks ?!
