RCU Forums - View Single Post - EDF Boat HELP Needed
Old 10-09-2015 | 02:53 PM
Got RPM's Avatar
Got RPM
I found that if I tried to run on the front step only the boat porpoised terribly and would flip if I kept in the throttle too long. This was accomplished by moving the CG, jet thrust vectoring alone will not be enough. I was constrained by the semi-scale design, you will not be.
A float plane rides on the front step by using wing lift to stabilize the attitude, which we do not have. Getting a balance between CG and thrust vector to keep the boat on the front step only will be a challenge. Float designs vary so yours may be more - or less - forgiving than mine.
The upside is that running on both the front step and the transom is still a huge reduction in wetted area and drag over a solid bottom, or especially compared to a flatty. While it would be great to be able to run on the front step alone, it is probably not too practical especially for a prototype. I suspect that you will have a fine running EDF boat with the CG behind the step.
Did you see the videos? I will try to post more.
https://m.youtube.com/watch?v=C65C7C...ature=youtu.be
https://m.youtube.com/watch?feature=...&v=QxzdlF5GPN0
