No, no wiring change. Maybe you're thinking of me going on about bracing the antenna on the lemon Rx receivers I keep using lately.
I have HS65HB's on R/E, and an old GWS micro on the throttle.
176 sq in and 13.4 oz., 11oz/ft^2
I'll try to get another data point after putting in more than one flight on a fresh battery. I have a micro switch harness between the Lipo and the regulator, and the regulator plugged into the Rx. So I can use the charge plug for the battery and no trickle current drain on the battery to forget about and kill the LiPo (done that before with plug-the-cable-into-the-Rx type switches..).
