Just completed 4 12 min flights. Needle valves are far less critical than my older 10cc. Getting about the same rpm with break-in props. Fourth engine run with 12x6 APC max rpm a little over 10,000. Mufflers is holding together, had to re-torque mounting bolt twice. RPM holds steady throughout the flight.
