Well, it works fine! No idea what the problem was so it may occur again. As for the insensitive needle setting, the plane has a lot of flights and I suspect the remote-mounted needle orifice may be worn. I had that happen on another 46AX a while ago and replacing the needle valve got normal operation back again.
