I have 4 flights on mine, the first two were kinda shaky. It does fly different, but I am very satisfied with the plane. My CG is a little nose heavy at the bolt hole in the fuse. I also moved my tank forward to where it is centered on the CG. If you build as per instructions the whole tank is aft CG.
