The biggest problem with the Genesis is the 36x75mm motor - it is far too small with too high a Kv for such a large boat. Depending on the strut setting and the CG, a 45mm prop on 4S may cook the speed controller.
I suggest you go to
www.offshoreelectrics.com the forum there has a lot of Genesis builders who can give you well-informed suggestions.
