Originally Posted by
Mi-25
Hi ZB,
I'm using an Airpower (Power Distribution Systems) PDS-620A connected to a Futaba 14Mz Rx, but want to remove the Fut and use my Jeti CB200.
My Q is: How do I connect my Jeti CB200 to the PDS-620A??
The problem is that the 620A requires power connected directly to it; but then the CB200 also needs direct power input?
Am I correct in assuming that anyone using a Powerbox has the same problem?
many thanks,
Leon
The CB200 is a power distribution center as well and you don't want to use 2 of them in the same airplane. If you like the way the PDS620A works and want to keep it, simply replace the Futaba receiver with a regular Jeti receiver such as the R14.
Personally, I would simply remove both the Futaba receiver and the PDS620A and install the CB200 in their place. If servo travels, etc are set through the PDS620A then you will simply need to redo your servo setup via the transmitter. You will need to do this anyways since the Jeti transmitter provides greater servo travel than JR, Spektrum or Futaba for the default servo end point settings. t
