Originally Posted by
lxfly
Why using a PDS with the CB200?
Do you need 6V for servos or HV? On HV, just connect your batteries to the CB200, for low voltage just use a BEC system from Jeti or a Powerbox Gemini 2, there may be more.
Hi René,
I originally set up my plane with the PDS/Fut Rx and afterwards bought the Jeti. My Q is; do I need to ditch my PDS system if I want to use CB200 plus Rx's? Or is there a way to connect? I use 6v servos.
many people use Powerbox systems...if they use Jeti do they remove Powerbox completely?
