Originally Posted by
Dave Wilshere
Its a single access rudder gyro.
any 112 (4 1/2") turbine will use 2 spacers per side. You can see in my build pics
Is the wing tight because of the wing clamps? I had to sand the end of my carbon tube-that's normal
I enjoyed flying the Plus at Jetpower on Saturday, the wind was horrible on Friday, but Saturday was nice conditions.
Dave
Dave in regards to the engine placement, I've determined that I need both or all 4 shims to install the turbine. My question is, for you experienced builders. How or what tools did you use to get in there to actually month the turbine in place? I'm putting a kingtech 140 in mine and there is hardly any room to get in there to drill a hole let alone get a screwdriver perpendicular to the mounting surface to ensure the screw is straight through the wood. Just curious. Thanks
Brian
