RCU Forums - View Single Post - Stihl MS660 big bore conversion.
Old 10-14-2015 | 12:01 PM
  #31
Jim.Thompson's Avatar
Jim.Thompson
Originally Posted by ZAGNUT
would be wise to go with C3 bearings. most large two strokes use that or even looser.
standard clearance CN bearings will often die prematurely in this type of application.
Ok, I will look for C3 clearance bearings. I had not thought of that rating. Long time since I struck such terminology.
Originally Posted by w8ye
The clutch side bearing is 17 X 40 X 14 and is a Stihl bearing Notice that it is wider than standard?
The flywheel side is a 6203 which is 17 X 40 X 12
It might not make any difference on the rear bearing - being as you are going to cut the crank off and put a plug in the hole?
Yes, the clutch side bearing is a 14 mm wide one. However, at least some of this width is taken up with the special internal seal, so I assume that the effective race width is much less. That is why I figured that a 12 mm wide after market replacement would suit, with a 2 mm spacer fitted if necessary. I am going to cut the shaft off and fit a bearing retainer/crankcase cap.
