cotman , I would start with setting the CG at 4-3/4 to 5 " at the root , balanced inverted . Note : the elevators are very sensitive even if using a forward CG ,use reduced rates and plenty of expo for initial flights until you get the CG dialed in . There are several flight trimming charts to be found online that will help with CG fine tuning ,lateral balancing etc...
