RCU Forums - View Single Post - Trying to get started on a complicated electronics package; could use some help.
Old 10-18-2015 | 08:30 PM
YHR's Avatar
YHR
I would suggest you get everything working as per the Clark instructions first. Once you get it working as per Clark's default set up, you can then look at re-assigning the channels more to you preferences. That is how I worked through my first Clark install, and ended up with something that mimics the HL set up
Cheers
