RE: Need CA Hinge Help
The 1" length goes into the wing so you will have a 1/2" into each surface minus the pin if you use it for a spacer and the .7 dim. goes sideways to the wing or what ever your doing.
Also for best results you should drill a 3/32 hole in the center of each hinge slot and that will help the glue get into the hinge better.
JIM
