RCU Forums - View Single Post - Sig Kadet MkII build
Thread
10-22-2015, 12:52 PM
23
KenChoo
Top Flite 182? Who knows, maybe one day. I gotta build up to it though (pun intended). :-)
In the meantime, here are some more pics for today. I took a photo of the paper templates I drew for the shear webs...I took measurements of the bay using a ruler and two triangles. The triangles helped me to get the proper angle to cut the sides of the webs - I'd first lay one triangle vertically on the top spar, then laying an edge of the other triangle against a rib, I'd clamp those two triangles together with my fingers and take them to a piece of paper and copy the angle. The ribs were pretty square all around (except the root rib) so I didn't really have to do this, but it helped with good, tight fitting joints (see pic). I could have also used the dihedral angle gauge to help with the root rib web so this process wasn't 100% necessary...I just found it helped me.
Other than that, it's just chugging along with more sheeting and cap-stripping till I've got a left panel also completed! Next is more sanding then epoxying the two sides together.
01:07 PM
Reply
Like
KenChoo
View Public Profile
Send a private message to KenChoo
Find More Posts by KenChoo
View iTrader Profile
