Thanks Tom - aren't you at Arvin? Districts? My goal is to get this plane flying better than the Venus. An interesting challenge for me. Yes on the Cannalizer, I hear 1" rudder throw - which is very intriguing to me for any reasons. I will be sure to check my servos closely - clearly they must center. If you read the above, I need to send my wings back as the rear wing tube does not insert all the way on either side. This is a bummer as the wings look very straight - not perfect, but very good. I will be connecting my elevator and doing all the normal adjustments with my parallel sticks - and this will tell me if this servo does not center properly. Putting on the Cant now and having trouble with one screw - not sure what it screws in to - I see now wood there. It better align with the stab when I get it mounted! Thanks for the info. sc
