The 15x8 should be a good place to start. It's on the low end of recommended props, so it will give you enough head room to allow for quirks of your particular power system. The final decision on props will be determined by your measured amp draw and, of course, flight performance. That motor is designed to be a direct drive system, so no gear drive is needed.
