Because it is a reed valve engine, all you have to do is relocate the timing sensor. You'll probably have to drill two new holes, time it for clockwise rotation and go fly it!
Thrust is still the same on all the bearings, etc. The rod will be thrusting the piston from a different side but that is no different than when same type cylinders are used on a twin. I can see no issues.
