Originally Posted by
big_G
The ring might be the carbon fiber motor mounting plate, for front mounted motors. Mine is a rear mount motor, a plywood mount is available. The paint looks like automotive grade...I'll bet it holds up fine.
Thanks for the info. Once you get the motor mounted on your Caelus post a pick of the structure inside the fuse and how you mounted the motor.
