Originally Posted by
CGNoorloos
Should one oil the tracks too? Quite new myself much like the OP, so thanks for all the above info. The times the tracks where really dirty i cleaned them in some warm water(not hot) and used a little diswashing soap and brushed them clean. But when they are just a little dusty i don't clean them, is that any problem?
Brett has already answered this but we often drive thru water at our battle days and sometimes it can be messy. I would avoid washing the tank much. You don't want to force dirt or water into the wheel bushing/bearings. Normally just holdin the tank up in the air or atop a wood block and driving at top speed for moment in each direction will suffice. I got totally mudded at Brett's house two years ago. I washed the track (the only time I have ever done so) at the hotel room at the next Danville event. Tracks are not much of a wear item so no lube needed. Oil and lubes must be protected from debris and contained from going where not needed.
