RCU Forums - View Single Post - Need CA Hinge Help
Old 10-19-2003 | 12:37 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Need CA Hinge Help
ORIGINAL: Balsa Master
get the pin kind that you drill a hole for, there easier than the slot hinges (since you still have to make sure that the slots line up)
So let's see. With the pin type, you have to line them up both horizontally as well as vertically. This is EASIER???
I use both types of hinges, and CA hinges are easier to use BY FAR.
And they work great if they are installed properly.
Here's a simple "How To" on installing them:
http://www.rcuniverse.com/magazine/a...?article_id=55
