Here is the Tamiya Leopard 2A6 DMD setup instruction manual in pdf .
http://www.tamiyausa.com/images/prod...20/56020om.pdf
Now I like to set my turret control stick so that full up fires main gun and full down fires machine gun .
How you do this is when programming stick for gun up/down elevation you only move stick up or down 1/4 in ether direction then after setup is done moving the stick full up fires main gun moving stick up 1/4 moves gun elevation up and works the same for elevation down and machine gun .
Also both my stick are self centering I like them that way .
Jimmy
