RCU Forums - View Single Post - Aileron set up
Thread: Aileron set up
Old 11-01-2015 | 08:16 PM
jester_s1
Moderator
No, always line up the aileron with the bottom of the wing. On many planes, that means the top will wind up reflexed a bit, and that's ok. If you set the ailerons with some down angle they will act as flaps in flight. That means your stall characteristics become snappier and you'll need more airspeed to have solid aileron control. It also will cause the plane to have pitch changes with speed changes, which will make precision flight trimming a real pain. It's even helpful on some planes to have them up just a little, but probably not on yours.
Here's the reason. On the bottom of the wing, you have this smooth flowing, slow moving high pressure air that stays stuck very well to the wing surface. The angle of your trailing edge has a big impact on how that air comes off the wing surface and rejoins the air on the top. The top has this fast moving, turbulent, low pressure air going over it. Really, because of the turbulence, an aileron that follows the wing taper isn't in the real airflow much at all. In a non stalled condition, the aileron affects the air on the bottom a lot and the top a bit less. That's why you get adverse yaw; an aileron has to move up a ways to actually interact with the airflow, but any down movement has a big effect. And that situation gets even more extreme in a stalled condition. That's why some planes actually fly better with their ailerons angled up a bit compared to the wing bottom. For planes that are stall prone, (heavily loaded warbirds come to mind) just that simple change can turn a snappy plane into a gentle flyer.
