RCU Forums - View Single Post - Multi Charger Question
Old 11-02-2015 | 05:04 AM
jester_s1
Moderator
With a little soldering you can do parallel charging. Ohm's law says that current will flow to the lowest voltage first, so you can hook up 4 batteries to one output and they'll all finish at the same time. The only limit on that is they have to be the same kind of batteries and the same cell count.
