Originally Posted by
krokodyl
Ok so i recieved the os and i have an issue. First I cant remove the flywheel off my old engine. I held the flywheel and soun the bolt, For some reason the piston and all would move while i was unscrewing it. (counterclockwise) It wont move clockwise. Next, the clutch shoes are not exactly round when put together, they form an oval, not sure if that is good or not?
Put a wood dowel or a couple of zip ties into the exhaust port to stop the piston when trying to loosen the flywheel nut. The clutch shoes will usually look oval when not on the flywheel pins on a 2-shoe clutch. Sounds normal to me.
